Elliot22
Setting the alarm for my Invicta 6207
Can anyone advise me on the way to set the alarm function for this watch - It is not apparently covered in the instruction manual and frustration is setting in
Any advice would be sincerely appreciated.
I have the Invicta 6207, great watch, here is a short how to on setting the alarm
1. Unscrew crown and pull out to position 1
2. Turning the crown counter-clockwise  will move the Alarm hand. Turning the crown clockwise will adjust the day.
3. Screw the crown back in (must be screwed back in) and press the top pusher once and wait until alarm indicator goes to ON position. To turn off alarm press top indicator again. To turn alarm on crown can not be in position 1 because then the upper pusher is used to adjust the power indicator needle. Always turn on/off alarm when crown is screwed in.
Bottom pusher works for the GMT hand, if you hold it down it will advance fast.
Hope that helps
Hope that helps
thanks for your kindly help
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
