EdgyGuyJide
Omega Speedmaster Moonwatch
The day-to-day error is between +0 and +5 seconds, and even if exposed to the 15,000 Gaussian magnetic field, the high accuracy of the normal operation, which is Omega to the Observatory certification brought us a super practical experience. From the first of the Omega to the dawn of the Observatory watch the beginning of the watch, to Zhen astronomical movement has begun to promote the major series of Omega. Today, to reach the Observatory movement also entered the most legendary series of Omega series.
Speedmaster as the watch industry's most outstanding chronograph watch one, accompanied by astronauts 4 times on the moon's legendary experience, let itself become high-quality and precision endorsement. And in the possession of the Astronomical Observatory after the certification, so that this Speedmaster MoonWatch phase to reach the Observatory watch more impeccable.
Omega 9904 self-winding chronograph movement consists of 368 parts. Equipped with longitudinal wheel timing device and coaxial escapement. Movement and watch through the Swiss Federal Institute of Metrology (METAS) approved the "to the astronomical watch watch" certification procedures for testing. Can withstand up to 15,000 Gaussian strong magnetic field interference. Equipped with a silicon gossamer without card count hairspring balance wheel, two series of barrels, two-way automatic winding system. Central hour hand, minute hand and chronograph second hand, small second hand, calendar pointer, 12 hour chronograph and 60 minutes chronograph small dial, moon phase display. The rhodium-plated plywood is decorated with a Polish-style Geneva ripple.
After obtaining this super-series phase to the astronomical watch (model: 304.33.44.52.03.001), we also carried out a 6-position precision test, the error is very small, in full compliance with the day to reach the day The error is between +0 and +5. And, its six azimuth swing values are relatively high, it should also be the reason for its precise travel time. Omega 9904 movement equipped with two barrel, but the power reserve is limited to 60 hours, to increase its power supply, increase the swing value to ensure its accuracy.
Dark blue dial with solar rays polished, with rhodium-plated hour scale. And 3 o'clock position unique time minutes, clocked small dial corresponding to its 9 o'clock small seconds, and date display small dial. Unique double needle layout, but when reading is still clear.
Hour scale and the middle of the three indicators are attached to the luminous coating, to ensure that the time in the dark to read.
The moon phase shows the use of microstructured metal crystal discs, the pattern is selected by the United States National Aeronautics and Space Administration (NASA) shot the moon photos, the details of the surface of the moon portrayed lifelike, to reproduce the real surface of the moon scene. Under scrutiny, you can even see astronauts leave a footprint on the moon. Unlike the normal moon phase display, this moon phase display with a high-precision mechanical device, running 10 years to be adjusted once.
There are 8 different materials with color watch, we get the hand is the steel material blue watch, 44.25 mm case diameter, dial, bezel and strap are used in dark blue very beautiful.
Crown operation feel comforwatch, time, date display and moon phase can be rotated through the crown debugging. Crown on the bottom of the timing button under pressure feel heavy.
As the mirror with a convex mirror, an increase of the side of the watch thickness, worn in the wrist is very texture.
Omega's original Liquidmetal® technology creates a blue ceramic bezel with speed scale, rugged.
Blue crocodile leather strap, white pressure line with stainless steel folding clasp, easy to wear.
Summary: equipped with Omega 9904 self-winding chronograph movement is definitely the timing of today's watches for the benchmark. Not only practical, moon phase display also makes the watch more beautiful. At the same time, access to the Astronomical Observatory certification not only in the travel time accuracy has improved, its 15,000 Gaussian high magnetic security assurance also let the watch in the daily use of peace of mind. This blue steel case super series series to the astronomical watch watch price of 76,000 RMB. As a technology to reach the industry's top level of the moon phase watch, cost is very high, worth buying.
