EdgyGuyJide
Rolex Sea Dweller
As early as 1967, Rolex launched the first oyster perpetual constant-action Sea Dweller diving time. 50 years, the series of each new products are adhering to the excellent waterproof function and unique Oyster structure design, as the watch lovers in the eyes of the ideal one of the diving, is also regarded as a professional diving timepiece of the legendary The In 2017, at the prestigious Basel Watch Fair, Rolex once again in this legendary series of new sea to the climax, the size of the case to enlarge and into two new elements, so that it is full of charm it Tim luster, as the table on the most weight of one of the masterpiece. Here, and watch the family together to see.
For the first time the single red words and blister into the modern Sea Dweller
       Rolex for the first time the two classic design of the brand into the new sea to dive table dial, one for the watch in the bottom of the SEA-DWELLER brand series of red letters marked, bright red for the dial to add a touch of color beauty, highlight the brand sea to type Features, pay tribute to the first generation of Sea Dweller watch. Two for the Rolex date display magnifying glass, before the Sea Dweller diving table is no calendar magnifying glass, because the first sea to make the watch diving depth and mirror material limitations, out of the safety considerations for the watch, So has been useless. Until the blue crystal glass watch the prevalence of today, the strength is not a problem, so the join, not only the expansion of the calendar function, but also a series of enhanced quality of the signal.
In addition, there is a slightly magnified stainless steel case
Rolex Sea Dweller of diving watch
       Before the Sea Dweller diving watch case size of 40 mm, the new sea to the case design for the 43 mm, it is more refined, full of ornamental. It is worth mentioning that in the case of increasing the diameter of the watch, the watch thickness remains unchanged, making the senses become "slim" some, so that the overall structure more harmonious.
904L stainless steel case
       Equipped with 43 mm 904L stainless steel case, in the polished process after showing a great sense of enjoyment. Equipped with sea-style one-way rotation 60-minute scale bezel to the brand developed patent black Cerachrom word circle, and easy to scratch the ceramic made, even by ultraviolet radiation will not fade, highlight the brand stability rock quality. Patented helium valve is located on the side of the case, in the dive can keep the watch internal and external pressure balance, to prevent the helium can not be discharged when the formation of internal and external pressure difference, damage the watch.
Rolex patent waterproof crown
       As in the past Sea Dweller diving table, the use of Rolex patent waterproof crown, screw-in triple lock three waterproof system can watch the watch when the waterproof performance, very reliable.
Black dial
       Full texture of the black dial, after PVD coating technology after the time scale is more detailed, and the central time seconds and seconds against each other, showing Rolex diving table unique dial charm. In addition, the pointer and the time scale covered with Chromalight luminous coating, in the darker environment emitting Yingying blue light, making the moment to clearly show, very beautiful.
3235 movement
       Such as Rolex Oyster-style watches in the end of the process, to protect the outstanding water resistance and airtight, very reliable. Equipped with 14 patented technology brand-made 3235-type movement, with 70 hours of power reserve. Configuration Rolex new patent Chronergy escapement system. The new escapement system is made of nickel and phosphorus, not only efficient and reliable, but also from the magnetic field interference. This is the first time Rolex will be the latest movement used in sports watches.
904L stainless steel solid chain oyster bracelet
       Classic Oyster-style three-row chain bracelet, connecting an oyster insurance discount, with Rolex Glidelock extension system, through the fine tuning, so that the watch is more fit with the wrist, not easy to fall off, very reliable.
Summary: excellent and powerful superior performance and excellent style, making this Rolex sea diving watch has become a hot topic of concern this year. Especially the dial and table diameter changes, and the use of 3235 movement, it is full of infinite freshness and attractive, so many watch enthusiasts heart.
