Specs:
Model CEX0R001W
Mechanical Caliber 46R41 w/ 21 jewels
21600 bpm
40 hour power reserve
Date indicator
Mineral dome crystal
All SS case and bracelet
Double push button fold over clasp
50m WR
Case diameter ~41mm not including crown
Case thickness ~11mm
Lug width ~22mm
Bracelet width 22mm tapers to 20mm at clasp
Weight (guess ~150 grams)
Foreword: A substantial dress watch. Oxymoron or not, this watch has a lot of presence on the wrist. If you are like me, and have become accustomed to wearing larger than 40mm watches, this watch will not disappoint. If your looking for a dressy watch for a fabulous price (~$140) and one that has a larger case then typical dress watches this is a looker. It also comes in black and blue.
Pictures: The indexes and hands are all chromed. Do not let the reflections fool you. The white dial is just that. It is not polar white, but rather a pure white. Compared to the white fabric it is pictured with, it looks a little off-white slightly creamy.
Face/Dial
A classic look with a classic font. Sharp pointy hands and indexes with 8 lume pips and lumed hour and minute hands. The lume is no good, it lasts 2 hours tops, but this is a dress watch right!
What I wish Orient had done here is put a black line in each index and on the hour and minute hands. In very low light this watch is hard to read. In moderate to good light it is very legible. The black line I speak of would solve the low light issue. Oh well can't have it all with this kind of price
The dial is gorgeous. The diamond pattern/waffle/honeycomb what ever you want to call it is really sharp. The PRI within this pattern has it's own texture. This same texture is found around the perimeter of the dial as well as printed second tic's and 1/5th second tic's.
The Orient logo, the textures, the fonts, the whole layout....this is a good looking dial.
Case/Crystal
The case is all SS. The sides and case bottom are polished...the lug tops are brushed and the stationary bezel is polished. The case bottom is screw-on and the Orient logo looks beautiful. The crown does NOT screw down and rotates freely when pushed in. One click out and setting the time is smooth. The crown also sports the Orient symbol.
The date is advanced by using the recessed pusher @ 2 o'clock. Some might like this who do not favor the Mako pusher, but in reality it is not the most convenient way to change the date. You have to have a pen, pencil, toothpick, paper clip, etc... to change it. Could not get my fingernail in there
The domed crystal is really domed! It's a pretty sight I love it. It looks thick and gives a very rounded look to the case. Reflections are not an issue.
Bracelet/Clasp
The bracelet is exactly like the Mako bracelet (sans the clasp) for those of you who are familiar. Open end links and solid brushed SS bracelet with polished sides. Brushed clasp with the sides polished.
OEM sized to 7 1/2” wrists the links use the same split pins of the Mako bracelet. Size is 22mm at the lugs and tapers quickly to 20mm all the way to the clasp.
The clasp is stamped with the Orient text logo, has 2 micro-adjustment positions and is a fold over double locking type.
Opinion
I do have a few quibbles about it's legibility in very low light. For me, a watches legibility is way up on my priority list. But then again this is a dress watch (at least for me) and how often will there be a situation that I have to read this watch in very low light right!
It is a great size imo...every dimension about it.
Accuracy so far....just like my Mako when I first bought it....about 4-5 seconds fast per 24 hrs. Will update after some wrist time.
Now lets look at that bulbous crystal one more time and play with some lighting
