Omega Constellation Authenticity
Started by
watchkeeper-
, Apr 24 2015 05:13 PM
10 replies to this topic
#2
Posted 24 April 2015 - 05:13 PM
I can say without much doubt that it is a re-dial as far as I know omega never made a dial that colour, however I'm not a walking encyclopaedia on Omega dials and it could be original, the fonts are correct and it has -swiss made- at the bottom so if it is a re-dial it's a good one.
Matt
#4
As I thought, it is a good one though, if you don't mind the fact and the rest of the watch is ok then it's up to you.
The only thing I'd want to know is what state is the movement in, I mean why did it need a re-dial? If it was water damage then is the movement ok?
If it was me I'd look for one that was in original condition, there are many out there to choose from and don't forget to factor in a service, if you get it done you'll know it's done
Good luck with whatever you decide
Matt
Brought to you by HYPNOTOAD
#5
Dial is not original, it has been white/silver. Stupidity to alter it, even it is a nice looking. This one has a ladies movement 672 in it (only two hands), but it is a gents watch. This model does not have any gasgets so original dial has been water damaged.
#8
I agree here. It is a good redial. However the movement is the key. If the movement is clean, well running, and recently serviced, Id say go for it. But without knowing I would stear clear. Vintage Omega servicing can get expensive. (It was around 500usd for my Omega Seamaster deVille to be serviced)
Just some food for thought.
G.
#9
I would make sure you know the size of the case. The cal. 672 is definitely a ladies cal. and the case may well be small though I think its a little wider then the ladies cal. 672 constellation I remember seeing pics of. OP should be aware that if case is less then 30mm it may present smaller then expected.
#10
I think there is a decent chance that this is an original dial. Omega started going a bit nuts with colors in the late 1960's and 1970's. I've seen blood red dials on these that I know were original.
Here is the listing from the Omega Vintage Database:
OMEGA Watches: Vintage Watches Database - Ref. 153.0017
It is so difficult to tell the originals from some of the redials. The only way to be sure is to examine the watch in person.
gatorcpa
0 user(s) are reading this topic
